After a WinXP crash during a sync I now cannot get past the "Building music databases..." comment. I have loaded the 2.00 release dev image (and hijack kernel) but am unable to get to the prompt to try this fix. One other questions: When prompted to enter q, why is there "0 seconds to comply"?
Anyhow, here is the serial output on a boot. This output is repeatable.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v340 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Jun 18 18:40:14 EDT 2003
empeg-car player (hardware revision 9, serial number 40103994)
Command line: mem=16m
Memory: 15016k/16M available (976k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005e80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:9
a
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...•Ô•j½Õ¹Ñ•‘É½½Ñ¡•áÑɁ™¥±•ÍåÍÑ•µ¥É•…‘½¹±å¹)5ÿchang
e_root: old root has d_count=1
Freeing unused kernel memory: 4k initqempeg init 0.8
Mounting proc
Starting player
qHijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Tuner RDS Control"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
attempt to access beyond end of device
03:04: rw=0, want=519859964, limit=29219400
dev 03:04 blksize=4096 blocknr=-943776834 sector=1039719920 size=4096 count=1
03:04: rw=0, want=782784500, limit=29219400
dev 03:04 blksize=4096 blocknr=-1414916612 sector=1565568992 size=4096 count=1
03:04: rw=0, want=993534012, limit=29219400
dev 03:04 blksize=4096 blocknr=-288487410 sector=1987068016 size=4096 count=1
03:04: rw=0, want=1698163772, limit=29219400
dev 03:04 blksize=4096 blocknr=2035153678 sector=-898639760 size=4096 count=1
03:04: rw=0, want=84608716, limit=29219400
dev 03:04 blksize=4096 blocknr=21152178 sector=169217424 size=4096 count=1
03:04: rw=0, want=432155148, limit=29219400
dev 03:04 blksize=4096 blocknr=-428832126 sector=864310288 size=4096 count=1
03:04: rw=0, want=1947760272, limit=29219400
dev 03:04 blksize=4096 blocknr=1023810979 sector=-399446760 size=4096 count=1
03:04: rw=0, want=265262044, limit=29219400
dev 03:04 blksize=4096 blocknr=66315510 sector=530524080 size=4096 count=1
03:04: rw=0, want=1705136152, limit=29219400
dev 03:04 blksize=4096 blocknr=-647457787 sector=-884695000 size=4096 count=1
03:04: rw=0, want=577827932, limit=29219400
dev 03:04 blksize=4096 blocknr=1218198806 sector=1155655856 size=4096 count=1
03:04: rw=0, want=106772240, limit=29219400
dev 03:04 blksize=4096 blocknr=1100434883 sector=213544472 size=4096 count=1
03:04: rw=0, want=999072724, limit=29219400
dev 03:04 blksize=4096 blocknr=-1360844556 sector=1998145440 size=4096 count=1
03:04: rw=0, want=947018000, limit=29219400
dev 03:04 blksize=4096 blocknr=-1910729149 sector=1894035992 size=4096 count=1
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for bl
ock 4429881
ock 4429881
ock 4429881
ock 4429881
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo
ne - block = 1560657735, count = 1
Remounting filesystem read-only
ne - block = 3322813680, count = 1
ne - block = 184113030, count = 1
ne - block = 3163721723, count = 1
ne - block = 1076050864, count = 1
03:04: rw=0, want=1725699624, limit=29219400
dev 03:04 blksize=4096 blocknr=431424905 sector=-843568056 size=4096 count=1
EXT2-fs error (device ide0(3,4)): trunc_indirect: Read failure, inode=132342, bl
ock=431424905
03:04: rw=0, want=897831304, limit=29219400
dev 03:04 blksize=4096 blocknr=-312413087 sector=1795662600 size=4096 count=1
ock=-312413087
03:04: rw=0, want=1775376432, limit=29219400
dev 03:04 blksize=4096 blocknr=980715019 sector=-744214440 size=4096 count=1
ock=980715019
ock 4430918
EXT2-fs warning (device ide0(3,4)): ext2_free_inode: bit already cleared for ino
de 132342
Restored terminal settings
ock 4420368
ock 4420368
ock 4420368
ock 4420368
ne - block = 3351190462, count = 1
ne - block = 2880050684, count = 1
ne - block = 4006479886, count = 1
ne - block = 4294936511, count = 1
ne - block = 4294967283, count = 1
Kernel panic: EXT2-fs panic (device ide0(3,4)): load_block_bitmap: block_group >
= groups_count - block_group = 131071, groups_count = 223
*** End of output ***
MK2a 160GB
11 Years later, these Mk2a units still rock...
