Here is a successful boot log. Both are with the newest Hijack you posted.
Thanks,
Stu
Okay, when it fails, it's because it sees an endless stream of "data" coming in over the tuner serial port. Which is somewhat peculiar.
The failed boot appears to have happened while "docked", right?
Do you recall if the "successful" boot was also from a home dock" ?
Here's a kernel that should fix it, by putting an upper bound on how long we're willing to listen to the "tuner" sending us serial data:
http://rtr.ca/v467pre.zImage
Let me know what happens.. if it boots up, then reinstall the animation and verify that all is working again. I'll then release that as Hijack v467.
