I can no longer make it fail to boot, but I can give you a boot log with successful DC detection and without. The strange thing is even when Hijack thinks it's in AC mode, the boot log reads DC. I am wondering why the disconnect?
That's simple: When it's on DC and Hijack thinks it's on AC, this happens because the home-dock loopback test succeeds
By the way.. if you really don't care about "home-dock" detection (via the tuner serial loopback wire), then you could go into the Hijack menu (long knob press), and change the Force AC/DC Power Mode setting to No-Loopback. It should then boot up in DC mode every time while docked.
But one should really try and figure out why the dock detection works sometimes, and fails other times due to noise on the loopback wire.
