*edit*
Found the correct properties menu. It's annoying that there's a different properties menu for the same connection depending on if you get to it through IE or Network Connections. I think it's getting solved.
I seem to remember there being some way to see exactly what is being run at startup (aside from the "Startup" program folder). What was it?
Edited by DiGNAN17 (17/01/2004 17:35)
