Follwed the upgrade guide word for word. Everything seems to have gone along properly, but when I try to connect to the player with Emplode it gives the following error and stops:
"Download Failed while Rebuilding Database - Error 0xc0041002"
Here's what my Hyperterminal log looks like during bootup:
hda: IC25N080ATMR04-0, ATA DISK drive
hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:4
b
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Starting player
player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
b
Partition check:
Freeing unused kernel memory: 4k initwarning: can't open /etc/mtab: No such file
or directory
Making first drive...
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
Linux ext2 filesystem format
Filesystem label=
609728 inodes, 78043770 blocks
0 blocks (0.00%) reserved for the super user
First data block=1
Block size=1024 (log=0)
Fragment size=1024 (log=0)
9527 block groups
8192 blocks per group, 8192 fragments per group
64 inodes per group
Superblock backups stored on blocks:
8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409, 663553,
1024001, 1990657, 2809857, 5120001, 5971969, 17915905, 19668993,
25600001, 53747713,
Writing inode tables: done
Writing superblocks and filesystem accounting information:
b
Partition check:
empeg init 0.8
Mounting proc
Starting player
Vcb: 0x4086d000
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 40103915)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004880).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
b
Partition check:
Mounting proc
Starting player
q
rw
rwm
cp -auvfx /drive1/fids /drive0
Vcb: 0x4086d000
ro
Restored terminal settings
Restart code received
Starting player
rom
logout
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004900).
b
Partition check:
Mounting proc
Starting player
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004980).
b
Partition check:
Mounting proc
Starting player
Vcb: 0x4086d000
Any help would be appreciated.
Bodybag - So Cal
Not a Whiner any more!!!
