do you think I would get better sound if I addedd a optical out from the empeg and ran that into the alpine or just use the rca's
Probably depends on what's in the Alpine unit. You'd definately eliminate the risk for ground loop whine though - but proper wiring should handle that anyway. I'd try it with just the RCAs first and listen to the result, then evaluate...
/Michael
