#240831 - 09/11/2004 20:10
Re: problems with Mark II (possibly hard drive related)
[Re: JBjorgen]
Quote: Sounds like your disk may be dying. If you've gone through all of the FAQ entry for No Hard Disk found, I'd assume that's your problem. If you've got a spare notebook drive you can swap in to test it that'd be ideal. If not, PM me...maybe I can loan you a small one.
Have you checked the IDE header? Do you get the problem both in and out of the vehicle?
Hey. Thanks for your offer. If the hard drive/s is/are indeed dying, then I'll just bite the bullet and buy the two 60 GB laptop drives I was considering. I don't know how to check the IDE header. Does that mean opening up the empeg and checking to see if the cable is properling crimped? I guess I'm not sure what an IDE header is. I only have a docking sled in my car, but when I use AC power to turn it on, I have the same issue with it not bringing up the previous playlist. Is that what you meant? Thanks for your help.
Edited by nikko (09/11/2004 20:15)
