Any timeframe on this? 2 weeks? 4 weeks? Longer?
If the problem is the one I'm thinking of, you can solve it immediately in two ways:
1. Buying a different hub/switch, or using a crossover cable to connect the karma directly to your PC's ethernet card.
2. Using USB to synch instead of ethernet.
Is there any way I could help like enabling debug output or something?
Unfortunately the debug output of the Karma requires that a special piece of custom hardware be soldered into the base station. And anyway, if it's the problem I'm thinking of, we've already been through that route and narrowed it down to a hardware component.
