Yes, If you've got to factor an amp and speakers into each position your costs will quickly rise. One of the good things about the Rio Receiver was the built in amp. What would you use? Decent self powered speakers aren't cheap, and if you're looking at buying a micro-system to plug it into then you might as just use that. A multi-zone system sounds far more cost effective.
