#260969 - 20/07/2005 16:04
Re: Really weird networking problem
Quote: How about more basic stuff... Can the machine communicate with other PCs on its own side of the WAN? In other words, are we sure its NIC and driver and cable are all working?
And do you have another windows-based PC on this same side of the WAN that does work?
Let's also see an output of ipconfig /all for reference. Perhaps also an ipconfig /all for a computer that does work.
Yes
and
Yes
This is IPCONFIG /ALL from a working PC on the same side of the LAN:
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : flickpc Primary DNS Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : NETGEAR FA310TX Fast Ethernet Adapter r (NGRPCI) Physical Address. . . . . . . . . : 00-A0-CC-D0-0A-C0 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 121.1.0.90 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 121.1.0.30 DNS Servers . . . . . . . . . . . : 213.130.130.99 213.130.128.205 Primary WINS Server . . . . . . . : 121.1.0.254
