#262807 - 16/08/2005 09:11
Re: Steps for a large capacity drive, and memory upgrade
[Re: pgrzelak]
Quote: The default, based on a somewhat dated version number (1.03) in the FAQ is 180.
That FAQ entry is rather out-of-date. In v2final, chunks are 64K in size, and you get 40 of them on a Mark 1, 84 on Mark 2, and 134 on Mark 2a. In v3alpha11, those numbers are reduced to 28, 50, and 100. Any reservecache setting (in chunks) is subtracted from those numbers -- the default "reservecache" is zero chunks. The cache is then further reduced by memory allocated for the database: more songs, more reduction in cache (you can estimate how much reduction by checking the size of your database files on disk).
ratscrew
15/08/2005 19:11
pgrzelak
15/08/2005 20:03
Waterman981
15/08/2005 20:12
pgrzelak
15/08/2005 20:16
Waterman981
15/08/2005 20:19
pgrzelak
15/08/2005 20:29
Waterman981
15/08/2005 20:44
ratscrew
15/08/2005 22:03
ratscrew
15/08/2005 22:09
pgrzelak
16/08/2005 08:17
pgrzelak
16/08/2005 09:14
ratscrew
16/08/2005 14:48
