thump the SIDE of the player horizontally with the flat of your right hand once, maybe twice, HARD. If you do it at the right time, it may spin up giving you an opportunity to get your music off it. Good luck.
Are you nuts?
I'll pass on that method, thanks, as all my music is backed up already.Quote:
You will in any case be needing a new drive, unforch.
Yeah... As an update, I ordered 1 drive. I'll get it this weekend so I'll be replacing it and hoping it works fine. During the week, I'll be removing the old drive since the cable was glued on.
Squid2k1
18GB of revived Green Mk II Fury - Fast As A Shark
