#264418 - 07/09/200511:05Re: jEmplode Ethernet Problem
[Re: zexpe]
mschrag pooh-bah
Loc: Richmond, VA
So you are doing a direct connection (i.e. ip address is typed in) vs a broadcast, right? You might try broadcast to see if it makes a difference? Double check the address that is typed in in the options dialog to make sure it's valid and doesn't have any spaces or something weird around it?
Do you have more than one network interface on there?
