#266779 - 06/10/2005 14:34
Re: Tivo and Season Passes
Quote: I'm very suprised that the 30 second skip didn't work on yours. Are you certain you did it correctly? I find that the best way to do it is to play a recorded video
In my experience, that's the most common reason for the 30 second skip trick to fail. You have to make sure you're playing a recorded video from the Now Playing list before it'll work. Either that or you skipped one of the "selects" in the key sequence. The sequence, if you want to try it again, is:
- Go to the Now Playing list. - Select and play something. - Press: SELECT, PLAY, SELECT, 3, 0, SELECT.
If you've got sounds turned on, you should hear BONG BONG BONG at that point.
Thank both of you for the tips on that, I'll try it when I get home tonight. I never really gave it a second thought when it didn't work. I guess it is because the player is a Phillips (no clue what model) and I don't remember seeing it listed on that page of compiled hints/tips/hacks. I'll have to go back and check out it again.
Thanks again.
- Tim
