As my original post states, I am upgrading one of the drives of my 2-drive MK2. Meaning, I had before two drives. I am replacing one of them with a new bigger drive. At this point I pulled both of the original drives out of the Empeg, plugged only the new one in, with the jumper removed (since on the drive itself there is a chart showing device0 as no-jumper). Then I loaded the car2-builder image, which is supposed to be designed to format the drive. The upgrader software on my PC went through its thing...including it did that partition pump stuff (which seemed odd to me since the drive hasn't been formated yet). The drive was previously used as a WindowsXP drive and has that junk on it, maybe it confused things because of that? In any case, when the screen on my PC said it was finished, I unplugged the power to Empeg and restarted it, with hyperterminal on.
At that point it did NOT go into any format mode. It flashed a bunch of boot up ascii text up the terminal within about 10 seconds (none of which included lines abuot formatting the disk and some of which had errors reported), then went into the health check that its supposed to do after formatting. I can do it again and copy and past the text if there is someone savvy in here you might know what is going on.
I thought maybe it worked and I didn't know it. so I tried to put the normal car-developer image back and tried to boot up, with hyperterminal on (this is all exactly according to the procedures explained on riocar.org's HD upgrade page). At that point there were errors I didn't understand showing up on the hypterminal. It looked more or less like things didn't work right so now I'm in a holding pattern.
Here is the hyperterminal output I see when trying to install the car2-builder image(which is supposed to format the HD)
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg49 ([email protected]) (gcc version 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 2001
empeg-car player (hardware revision 7, serial number 90000741)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHT2080AT PL, ATA DISK drive
hda: FUJITSU MHT2080AT PL, 76319MB w/8192kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:e5
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
okay
Freeing unused kernel memory: 4k initVFS: Can't find an ext2 filesystem on dev ide0(3,4).
mount: wrong fs type, bad option, bad superblock on /dev/hda4,
or too many mounted file systems
warning: can't open /etc/mtab: No such file or directory
umount: /drive0: not mounted
Making first drive...
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
no room for private writable mapping
error: -12
/dev/hda4: Memory allocation failed while setting up superblock
hdstress.cpp 189 ( 14): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Stressing /dev/hda: Spinning up.
Speed checking /dev/hda3
Read/write of 8Mb took 4.14 seconds
hdstress.cpp 1
