#274487 - 16/01/2006 15:33
Re: Help installing Java (+Jemplode) for a Linux newbie
[Re: petteri]
Quote: Ok, I just tried running jemplode.jar as suggested, seeing that a Java package is installed under Synaptic. I'm now seeing the "Jemplode splash screen" a fetus? But is is stuck at that. Do I need the Empeg connected to go any further? It's in the car at the moment (secure garage). Thanks again!
The current version splash is something about a Reunion Tour, so you should probably get the latest first. Then, if it's working, you should see a "Looking for Devices" pop-up, whether or not your player is online. IF that fails, well.. Jemplode seems fussy about which java interpreter is used..
