Okay, weekend is over, thanks for the suggestions so far. I opened up the Empeg again today. I removed the IDE cable, recrimped the connectors. Tried re-booting, no disk found. Rebooted with main connector being pressured into the motherboard, same. Connected the drive to the end of the cable, same deal. Again, there are a couple of pads (various locations) on the motherboard connector that show very little solder on the top of the pads. Wiggling the connector doesn't show any obvious signs of loose pads. So because it booted once, there's not a possibility that it is not a bad hard drive? Or a hard drive going bad?
How about a clean boot log to look at?
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v417 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Sat Jan 15 19:12:21 EST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30102917) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x98b7c
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHT2060AT PL, ATA DISK drive
hda: FUJITSU MHT2060AT PL, 57231MB w/8192kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:65
Partition check:
hda:hda: read_intr: status=0x59
hda: read_intr: error=0x01
ide0: reset: success
hda: read_intr: error=0x40
end_request: I/O error, dev 03:00 (hda), sector 0
unable to read partition table
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
