I would:
- check shield continuity on each audio channel at the sled
- likewise at the amp
Shield as in shielded wires? They're just straight up normal insulated wires. Should I shield them?
Or is there some shielding on the player that you're referring to?
- check the RCA leads
I swapped in a different sled (and sled harness) but that didn't help.
The RCA leads from empeg to amp are new, albeit cheap-o, as is the amp. Fiddled with all connections with no luck.
The whine disappears when I remove *all* four RCA's from the amp, so the problem is definately inbetween the car, player and the amp.
- remove the rolloff caps in your player.
Gonna have to search the FAQ for that one!
Thanks for the suggestions, Rob! I'll have another look tonight.
