Well Paul I have done everything correctly and according to hyperterminal everything went fine but when I run Emplode the 100 GB doesn't show up at all. Any ideas? Heres a hyperterm capture after the manual partition and format:
empeg-car bootstrap v1.02 20001106 (
[email protected])
empeg dsp audio initialisedRemounti
If there is anyone present who wants to upgrade the flash, let them speak now,g dsp initialisedn
empeg audio-in initialised, CS4231A rev
or forever hold their peace...it seems not. Let fly the Penguins of Linux!l/panel button initialised.order 4, 64k)Penguins of
e000 v1.04itialised,
Copying kernel...eceived SIGINT, u
Calling linux kernel...
(release)) #11 Tue Apr 1 18:49:59 BST 2003
1024
empeg single channel
Processor: Intel StrongARM-1100 revision 11interface...on table
hd
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.mpeg
hdb: ST9100823A, ATA DISK drive
Scheduli
ide
empeg-car player (hardware revision 9, serial number 30102798) o
hda: PhatNoise DMS 20GB, 19077MB w/2048kB Cache, CHS=38760/
Command line: mem=16m
empeg dsp
Calibrating delay loop... 207.67 BogoMIPS, 95396MB w/8192kB Cache, CHS=12161/255/6
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4sh driver initialized
Starting kswapd v 1.5
/sbin/f
SA1100 serial driver version 4.27 with no serial options enabledev/hda4
Command action
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTlesystem on dev ide0(3,4).
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTsettingsed
Remounting fi
smc chip id
No primary hard diskast c
Signature is 67706d65 'empg'cond music partition read-on
Scheduling custom logo.Stahlman (
[email protected]N
empeg display initialised.
Restart c
Starting player
empeg dsp mixer initialised : 385:empeg-car 2.00 2003
empeg dsp initialised
empeg audio-in initialised, CS4231A revision aed to op
e000 v1.04
Copying kernel...
empeg single channel IDEinux kernel...default va
Probing primary interface...inux........................
hda: PhatNoise DMS 20GB, ATA DISK drive
l logical (5 or ove
hdb: ST9100823A, ATA DISK drivep pr
l.ry
Linux version 2.2.1
ide0 at 0x000-0x007,0x038 on irq 6c version 2.95.3 20010315ype `n'
hda: PhatNoise DMS 20GB, 19077MB w/2048kB Cache, CHS=38760/16/63 l
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
