#282737 - 08/06/200618:56Re: Can't q or control c - causing big problems.
[Re: jbauer]
tfabris carpal tunnel
Correct.
If you pulled the power when you said you did (because you couldn't complete the procedure), then it means you rebooted the player RWM. That would definitly require the procedure to be done over again From The Top.
