Third time is a charm...
Unix version only, Correctly takes care of the # problem. Inside the script there is a debug flag to set... much status results when set, defaults off.
Command line options:
getmp3.pl Empeg_IP Directory_to_download_to
I *THINK* this is really good this time.
Unix users should only have to run the file, no hacking inside needed...
SHOULD.
Oh yeah.... If you store playlists in a Playlist labeled "Playlists", this script will happily ignore them. This works for me so I don't get duplicates. It might not work for you.
28917-getmp3.pl (358 downloads)
Synergy [orange]mk2, 42G: [blue] mk2a, 10G[/blue][/green] I tried Patience, but it took too long.
