The only odd bit is a resistor soldered in to the right of the IDE header. Maybe this is the fix for the very dim display which Stu applied recently. The MK2 worked like a champ after that job, with its fixed dimmer, new lighting kit, and replaced MK2a knob. Maybe something's worked loose?
No, that was done at the factory or shortly after to all MK2 units. I don't know what issue it addresses though.
All the work done was to the display board, so it's unlikely the problem. Just to make sure, run the Empeg without the display and grab the boot log, although I can't imagine it should make any difference as there is nothing on the display board associated with either the IDE or I2C bus.
Stu
