I have this player in front of me now and have replaced all the major components (DSP and both PEELs) outside of the processor that are in charge of I2C and the CS lines on the IDE bus, but the lost interrupts and I2C errors persist. I've checked the series resistors in the I2C lines and the oscillation for the DSP and they check out fine.
Any of the Empeg folks have any ideas what else there could be going on here?
Thanks,
Stu
I just finally fixed a player I have here that had I2C issues. It turned out that the power on pin 65 of the DSP was intermittent, so I resoldered that pin, plus the coil that feeds it (which is way over on the edge of the board past the CPU, and now it plays fine again.
