The only difference between consumer and developer builds is whether or not a shell prompt is available. You only need the developer build if:
- You need to do troubleshooting (such as manually rebuilding the database).
- You want to modify the default software or add additional software of your own (hacks and such).
Other than that, the developer build is not required, either for 3.0 or 2.0.
