Hey all..
I have a MkII unit and I upgraded the hard drive a couple of months ago. Things have worked fine since then. Then one day it said I had no playlists. I connected it to Emplode and that fixed that problem. Then I took it out to the car and it said no hard disk found. Now when I boot it up this is what it has on the serial port. I'm hoping that someone can tell me what is going on here. Thanks.. -Allistah
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v467 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Mon Jan 15 17:40:42 EST 2007
Processor: Intel StrongARM-1100 re
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101431) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80) --> no visuals for Tuner/AUX.
empeg state support initialised 0089/88c1 (save to d0004380).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x8080
ide_data_test: wrote 0xffff read 0x8080
ide_data_test: wrote 0xaaaa read 0x8080
ide_data_test: wrote 0x5555 read 0x8080
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
smc chip id/revision 0x0249
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
Edited by Allistah (04/06/2007 02:22)
