I rarely use Displayserver, but would like to keep it installed for when I do need it.... how can I turn off the "autostart"...?
You edit the init so that it doesn't start displayserver, and you can use either the serial command prompt to start it by hand, or use a custom "picker" program to choose starting it at bootup.
More details on how to use the picker program can be found here:
http://www.jps.net/tfabris/empeg/Picker_and_Voladj_for_Dummies.zip
Although it will take some modification to those files. Specifically, if you want to use the boot menu to start displayserver, you would edit "testinit" to remove the line that launches displayserver, then edit pick_list so that the second option (currently blank and unused) so that it launches displayserver.
___________
