how is it that a export is not the same all the way.. in the beginning it is one playlist fid followed by the songs of that playlist... but in my case the end of the export is pure playlist...
In general, the FID numbers are assigned sequentially,
as you create/upload playlists and tunes.
So if you were to reformat the player, then upload 5000 tunes, and
then create all of you playlists, what you would see would be
- The master playlist (FID 100h)
- 5000 tunes, numbered sequentially
- Your own playlists, numbered sequentially after the tunes.
Also, whenever you delete a tune or playlist, the FID for it is freed for re-use, and will be assigned to the next tune/playlist that you upload.
