the problem is that most of the export is sorted right..
first one playlist and then the tunes.. but over 2/3 down it gives me a big stack of playlists
(I'm assuming that the exported CSV does actually contain the playlist structure, i.e. the child-FID lists for each playlist -- I don't have an Emplode install around to check.)
since i have to check drive for error and such i think i will take the player indoor in 2 days time and start with a format and drive check. then i will add songs as i use to and then do the export and place a copy here
could a workaround be to only drop 10 winamp playlists in emplode at a time until all music is uploaded?
i only drop the playlist file itself not songs (i use the search feature in winxp so that i don't get any .mp3 files only .m3u)
