Originally Posted By: kjohanss
Next step is to get a device that remotely turns the power on and off on the network euipment so the battery doesn't run out of juice overnight. ... Anyone know of such device?
Yes, it's called an "empegcar" (or Riocar). smile
The way this has been done before, is to set the shutdown timer in the empeg to be, say, 20 minutes, rather than the usual few seconds.
This gives you 20 minutes to connect to the empeg over wireless after parking the car. After that, it shuts off. Use the amp-remote connection from the empeg to also switch power off on the wireless client box. No more battery problems. smile
A software hook is needed somewhere to prevent the empeg from shutting down while the wireless is in-use. I don't remember how most people do that, but it's an easy kernel hack if nothing else.
crazymelki had all of this set up rather nicely once. I wonder if the Search function here can find the details of his setup ?
