Any recommendations for the latest/greatest SSD? Looking for about 120GB. Don't really want anything tiny and anything bigger seems to cost significant amounts of $$$.
The OCZ Vertex which Mark is using seems to be pretty good. It supports something called ATA-TRIM as well which helps with the performance issues with a used drive. OCZ only supply a Windows utility which does ATA-TRIM or something similar but you need to manually run it periodically. Windows 7 apparently has it built in or will have it built in. Not sure whether there are any other implications for using ATA-TRIM.
Any others?
