These are 12V, which is what I would expect in the UK with that GU5,3 connector. Exactly as Larry says, you would want to factor in changing the lampholders over to GU10.
What I would sell here is the Lampholder at 1.25, and a Megaman Modo 4.5W GU10 (42W Equivalent, non-dimmable, available in 3000K and 4000K) at 8.00, that's all inc Tax. This is all in 230V though, but I would imagine you would be able to find something similar in 110V in Mexico, at the same price you're looking at roughly 190 Pesos.
I reckon you need at least 11w LED to come close to a 50w halogen, 14w would be more convincing. Our new house has these:
http://www.orluna.com/products/mini_recessed.aspxand these:
http://www.nationallighting.co.uk/LED_Lighting/LED_Fittings/LED_Downlights/LUCIDA/pid/988The 2nd ones are probably as close to a 50w halogen as I've seen from an LED but definitely not GU10. I know that Phillips, Toshiba and others do higher powered GU10s but the Phillips (which I've seen) has a little fan in it (v annoying).
An alternative might be CFL GU10s, I haven't seen any in operation but might be worth a look:
http://www.tlc-direct.co.uk/Products/GUC...CFc0mtAodfi4A9Q
