@mlord as I recall you are using voip.ms also, what setting are you using on you ATA and at voip.ms for DTMF tones?
I use a PAP2T-NA as the ATA. It has "DTMF Tx Method" set to "Auto". The voip.ms account also has "DTMF Mode" set to Auto.
DTMF seems to work fine for the few answering-system-hell companies that I still "press xxx to xxxxx" with. smile
