Andy,
Would you be so kind as to tell me how those instructions would differ if I were attaching this to a standard cable modem (one that's presumably already in bridge mode) that doesn't need to deal with PPPoE?
This would be the most common scenario. Thankfully most of my customers don't have DSL (I'm thankful for their sake).
Okay, all you need to do in that instance is plug up the office side to Ether2 and connect the cable modem to Ether1. Then, instead of typing in the bits for the PPP profile and PPPoE client. You'd need to do something like:
/ip dhcp-client add interface=ether1 disabled=no
You should be good to go. If you need to spoof your MAC address:
/interface ethernet set ether1 mac-address=XX:XX:XX:XX:XX:XX
