The thing with long coax runs is signal loss. With modern RG6 75-ohm TV coax, half the signal power is lost for every 50' of cable...
... Maybe if you had Moca adapters on the ends supplying the power...
Since there will be a (presumably) powered WiFi Access Point at the far end when
powered MoCa adapters are used, that was my original line of thought, not the passive coax gear.
Signal loss is not much an issue (within reason) when there are powered coax adapters at each end, especially if the coax is not split or otherwise running numerous places other than the Ethernet destination ends.
