In reply to:
Should I see the "Tuner Power Indicator" LED light up once it's plugged in, with car on, and Empeg NOT docked? Mine doesn't.
I can't see mine anymore to check that , but don't see how it would be possible for the tuner module to get any juice w/o the empeg installed, maybe it's in the wiring to allow it, I can't say.
In reply to:
Should I see a Tuner menu item on my Empeg even without the Tuner module connected once I install 1.03? I don't.
When booting you'll have to look fast mine says loading tuner something something. Then in the menu where PLAYLIST SOUND & such are there's one that simply says RADIO. Like I said in another post I didn't see this the first time I hooked mine up. Have you install tuner mod w/o the extension to see if it's a bad extension or plug? Or one of the pins on the tuner plug is missing or bad or not seated or well I'm just trying to go through what I would do yself I know I'd be like you & not want to send it back unless I really had to.
Hope something here helps.
#695-Mk2/Many pretty faceplate colors-12Gig/TUNER-anxiously awaits v2.x & VR
"No buyers regret"
