Rob,
If pathping doesn't do what you want, and you want to get to a lower level, Windows 2000 (yep, that again) has a built-in network monitor, called, surprisingly, network monitor.
It can be selected under 'Add/Remove' -> Windows Components -> Network Tools -> Network Monitor (from memory).
It allows inspection of each packet that the machine sees with filtering etc. It's not the best tool, but then it's free!
It's actually a cut-down version of the network monitor which comes with MS SMS.
Hope this helps.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
