Tony, I'll say it... Again... I understand exactly what you're saying. But now I'll tell you why you're wrong... :)
I've mentioned ealier... I'm using 1.03, not 2.0 as you've mentioned in your FAQ. In 1.03, the menu item for Shuffle does seem to be showing the STATE. The current state, before making the selection. What you describe as the functionality for 2.0 in the FAQ, seems a lot more intuitive.
For example. If I go to the menu and it says OFF, it means it is currently OFF. Pressing down will turn it on, but will never say ON. Until you go to the menu again to check the state.
When using the remote, pressing shuffle toggles and shows you what you have just changed it to - so in essence it is backwards from what appears in the menu, for version 1.03. Has there been any type of persistent (in whatever view setting) shuffle indicator added in 2.0?
So I'll check it off as something that's FITNR. :P
