So you will be able to stream from the HSX to a pc once some one comes up with the appropriate hack. However if i was to buy the HSX out the shop i would like streaming to come as standard. Would be a nice touch but i have every faith in this board coming up with something.
Now here is an intresting idea i may be wrong i maybe right but if the server bit of the software hogs to much memory could ou or someone stick out a speacial edition of the software which has bugger all in the way of a cache to save memory so the server bit could be run.
This would be good for those out there that have a spare empeg that could be pushed into use as a server for in the home.
P.Allison fixer of big engines
Mk2+Mk2a signed by God / Hacked by the Lord
Aberdeen Scotland
