If anyone doesn't bother to check the other areas of the message board, a rather interesting alternative to the lighted buttons is being discussed http://empeg.comms.net/php/showflat.php?Cat=&Board=prodject&Number=58298&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1
We're talking about using a sheet of indiglo material. This sheet is about 2 pieces of paper thick and can be cut into any shape and size. The transformer is really small (under 1" square) and runs off of 9 volts. This can be installed in the area for the second hard drive. It can be wired directly to the headlight sense circuit to allow nighttime use.
~Max
