I ran both leads directly to the battery, and used a relay to trigger the switched lead on the Empeg so that the relay only passes the current from the battery when the key is on.
If you didn't already - fuse those lines close to the battery. An unfused line that gets shorted to ground has the capability to set most anything on fire.
/Michael
/Michael
