It would take me to long to explain it, just goto http://www.r3mix.net to learn about the r3mix preset.
To edit the file simply go into windows explorer and goto the audiograbber directory(probably in your C Drive) and you should see the file. Right click on the file and left click edit, change the setting as described above and click file, save. You should be good to go.
