Somewhere in the configuration of your server you can set the order of files it looks for as a default display. Yours obviously has "index.html" and probably others ("index.htm"). In IIS (sorry, no experience w/ apache) it's under a tab in site properties or something like that. Add "index.shtml" to that.
Alternatively, as mentioned above you could enable your server software to check html files for SSI.
1998 BMW ///M3 30 GB Mk2a, Tuner, and 10 GB backup
