Maybe this will help someone. Here's the beginning of the what's displayed at HyperTerminal startup:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 9, serial number 10101453)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:a
d
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...•Ô•j½Õ¹Ñ•‘ɽ½Ñ¡•áÑÉ™¥±•ÍåÍÑ•µ¥É•…‘½¹±å¹)5ÿchan
ge_root: old root has d_count=1
Mounting proc
EXT2-fs error (device ide0(3,4)): ext2_check_descriptors: Block bitmap for group
0 not in group (block 1396520500)!
Remounting filesystem read-only
EXT2-fs: group descriptors corrupted !
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplùStarti
ng player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
