In reply to:
I thought that those compact flash readers required driver software support. I didn't think you could just plug one in.
That's the beauty of compact flash. It has three different interface types. One of them is called True IDE mode where the device emulates a standard IDE interface when certain pins are wired correctly. You can plug them straight into a PC if you want to. What you will need drivers for though is hot plugging/unplugging but this will also require buffer hardware which these cheapo adapters do not have.
Anyways this sounds very much like the problem where some drives don't like co-operating with each other.
