In reply to:
Depends what you mean by tech
Whoa. Not that tech.
I just pretty much mean the wiring aspect, or things similar. I'm going to wire 2 phone lines to every room, and have them, the network cable, the rg6, and anything else I run lead into a small closet, so as to be able to change most things from there.
I plan on building the theater room into the basement myself after the fact, so as to avoid getting the basement tax-assessed as "livable space".
I'm going to make sure a small garage window faces the patio so as to be able to mount a one of those Rio Receivers just inside, which will be hooked up to outdoor speakers. That way it will be protected from the elements and we can still control it with a remote.
I'm just trying to make sure that I will be wired with anything I might want for years to come. There is no high-speed internet option of any kind around here, but I would like to be ready when (if) it comes.
