#103216 - 06/07/2002 10:24 Power Fault Rio Mk2a
billius
I have just installed my Original Mk2 Empeg in to my nice new Landie. All works ok but..... I also have a Rio Mk2a which refuses to power up when plugged into the car. It works fine using the AC adapter but nothing at all in the car. I have changed the sled in the car from the original Mk2 Sled to a new replacement sled but still no joy.
Anyone got any ideas or am I going to have to send it back to Rio????
Thanks & regards
Bill
#103217 - 06/07/2002 11:00 Re: Power Fault Rio Mk2a [Re: billius]
lockuplever
Loc: Tucson, AZ
You're putting each of the players into the same sled, and only one is working, so we know the sled is wired properly, is that you're situation?
Steve
#103218 - 06/07/2002 12:02 Re: Power Fault Rio Mk2a [Re: billius]
Billius, this is a FAQ entry. Please click here for your answer.
#103219 - 06/07/2002 16:18 Re: Power Fault Rio Mk2a [Re: tfabris]
billius
Sorry, Didn't see it, I suppose I shouldn't spend 6 hours drinking at Henley regatta then look at the FAQ....doh!
#103220 - 06/07/2002 22:57 Re: Power Fault Rio Mk2a [Re: billius]
It's OK to miss something, it's a big document.
#103221 - 07/07/2002 06:27 Re: Power Fault Rio Mk2a [Re: tfabris]
billius
Ok, Just been out to check the wiring and all looks ok. Connections as follows:
Black - Ground
Yellow (Memory) - Always on - 12.2V
Orange - Ignition sense - Only on when ignition on.... 12.6V
So all looks ok to me, but Mk2a still doesn't work. What will happen if I give ignition sense permemant live... ??
Thanks,
Bill
#103222 - 07/07/2002 09:13 Re: Power Fault Rio Mk2a [Re: billius]
mrfixit
The unit should turn on... that is if the yellow wire has power too. Also make shure none of the pins have pulled out of the connector somtimes they could appear to be in but they might be pushed back just far enough not to make contact.
Ben
hijacked
#103223 - 07/07/2002 10:19 Re: Power Fault Rio Mk2a [Re: billius]
Yeah, billius, check here, too.
#103224 - 07/07/2002 11:29 Re: Power Fault Rio Mk2a [Re: tfabris]
billius
Ok checked sled all ok, tried making Both ignition sense and live live.... still no luck. The Mk2 is working properly, powering down when ignition is turned off etc. I wreckon there is a fault on the RIO. I've tried everything I can think of and read through the installtion FAQ from end to end...
#103225 - 07/07/2002 11:34 Re: Power Fault Rio Mk2a [Re: billius]
Wait a minute. Is it powering down when the ignition is turned off, or is it going into standby mode when the ignition is turned off?
If the Mk2 is not going into standby mode when the ignition is turned off, if it's fully powering down (probably accompanied by a pop from the amplifiers) then I continue to stand by my initial diagnosis: Installation wiring fault of some kind. There is nothing wrong with the player itself: it's getting power on the ignition line only and not the constant-power line.
If the Mk2 is properly going into standby mode when the ignition is turned off, then the wiring is probably OK and you should contact support.
#103226 - 16/07/2002 19:57 Re: Power Fault Rio Mk2a [Re: tfabris]
Bill Walker
Loc: NZ
Have now triple checked my wiring and it looks like I'm going to have to get hold of support ahh well....
MK II, (Blue but should be Amber) SN: 118
MKIIa
#103227 - 19/07/2002 15:39 Re: Power Fault Rio Mk2a [Re: billius]
Nobbie
Loc: Herts, UK
If you get no joy i'll pop over with mine sometime and you can try that in it.
Getting Old.
