#108594 - 31/07/2002 09:52 FireWire Empeg?
cookie_77
Quick question has any one looked in to enabling firewire on the empeg via the hard drive connector.
As you can plug a Firewire adapter on to a normal laptop hard drive and that Firewire is not a master/slave technology like usb could a hard drive to Firewire connector be used in reverse.
As mentioned before the empeg has no IDE controller , the drives are controlled from the processo.
Any ideas?
C.
#108595 - 31/07/2002 10:08 Re: FireWire Empeg? [Re: cookie_77]
No, nobody has tried this. Go for it. Let us know how far you get.
#108596 - 31/07/2002 16:31 Re: FireWire Empeg? [Re: cookie_77]
It won't work for firewire to talk to the empeg (not with a firewire->ide adaptor, at least); however, with some extra circuitry you could soft-switch the drive between the empeg and the firewire adaptor - but your PC would then have to deal with the ext2 filesystem (etc).
The IDE bus is the best (only?) way to fairly painlessly add I/O to the empeg, though.
