#109495 - 06/08/2002 03:30 Using US RioCar in UK (power cable question)
Simon K
Hi all... After years of wanting one i've finally joined the empeg club and should have my player in a few weeks. I'm in the UK and buying the player from the US (TTony's group buy in the "For Sale" forum).
What I would like to know is can i just cut off the US plug and replace it with a UK one?
#109496 - 06/08/2002 03:36 Re: Using US RioCar in UK (power cable question) [Re: Simon K]
Happy Birthday wfaulk
Most likely, the player you're getting will come with a power supply brick that has an IEC cord and socket (like the one on your computer). While the cord will be for US power sockets, you should just be able to swap out a UK one for it with no problems. And if you're like most of the rest of us, you've probably got dozens lying around.
#109497 - 06/08/2002 03:43 Re: Using US RioCar in UK (power cable question) [Re: wfaulk]
Simon K
Ahhh... a kettle lead Yep, loads of them! Cheers!
#109498 - 06/08/2002 04:21 Re: Using US RioCar in UK (power cable question) [Re: Simon K]
The two players I bought came with US adaptors. So I bought a power adaptor from Maplin for £10, works a treat. I also got an IEC PSU before the empeg shop closed.
#109499 - 06/08/2002 04:30 Re: Using US RioCar in UK (power cable question) [Re: Simon K]
David
Loc: Cambridge
All Rio cars in the US shipped with a plug-top adapter.
Maplins do a Sunpower MA15-150 which is the IEC type we used for UK players. I believe the slightly cheaper plug-top version is an MA15b, but check first.
Otherwise, any 11-15VDC power supply with a 2.1mm centre positive (v.v.important) connector will be fine.
#109500 - 06/08/2002 04:54 Re: Using US RioCar in UK (power cable question) [Re: Simon K]
thinfourth2
If you feel real flush an IBM thinkpad power supply is the business.
#109501 - 06/08/2002 05:37 Re: Using US RioCar in UK (power cable question) [Re: andym]
Simon K
Ok, i'm a little confused... are you all saying that I can't just swap out the US kettle lead for a UK one?
#109502 - 06/08/2002 05:41 Re: Using US RioCar in UK (power cable question) [Re: Simon K]
sundayjumper
Loc: West Berkshire
The power supply that came with my (US supplied) Empeg is definitely *not* suitable for use with 240VAC ! However, any UK power supply with the correct polarity & 12-16VDC output should be fine. The one from my scanner works OK, as does one I found at work that was originally used with an external CDRW drive.
Steve.
Mk2a 10+40Gb Darkstorm Neon Red Nakamichi CD45z, Genesis Five Channel, Genesis A16s, JL 8W6 x3
#109503 - 06/08/2002 05:50 Re: Using US RioCar in UK (power cable question) [Re: Simon K]
Apparently, I was wrong. David is the most likely to be correct in this discussion.
I was under the impression that all the Mk2as came with an IEC brick-style power supply, but I guess I was wrong.
#109504 - 06/08/2002 05:52 Re: Using US RioCar in UK (power cable question) [Re: Simon K]
tms13
Loc: Lochcarron and Edinburgh
If you get an IEC brick power supply with a separate lead, it will work with a UK supply using an ordinary kettle lead to replace the US lead.
If you get the US all-in-one supply that has the plug built-in, it's 120V only and you'll need to spend a tenner or so on a UK supply.
Does that make things clear?
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#109505 - 06/08/2002 07:00 Re: Using US RioCar in UK (power cable question) [Re: wfaulk]
Of all the MK2a's I ordered (8 in total), some came with an all-in-one PS (the 10 gigs) and others (the 60gigs) came with a brick-style PS.
