#111107 - 15/08/2002 17:11 High frequency cutoff in LAME with Audiograbber
maczrool
Loc: Louisiana, USA
I couldn't find a way to do this, so I am asking here. Is there a way to disable any high frequency cutoff that occurs in the encoding process when using the LAME encoder with Audiograbber? It doesn't have an option to disable it. I saw somewhere that you can enter "-k" to disable all filtering, but where would that go in Audiograbber?
Stu
#111108 - 15/08/2002 20:07 Re: High frequency cutoff in LAME with Audiograbber [Re: maczrool]
Ezekiel
Loc: NH USA
Well, one simple way is to use Exact Audio Copy instead of Audiograbber, but I hate to bring up religion... ;-P
-Zeke
WWFSMD?
#111109 - 15/08/2002 20:22 Re: High frequency cutoff in LAME with Audiograbber [Re: maczrool]
Ezekiel
Loc: NH USA
Actually, you need to use an external encoder such as LAME. When you do this you can pass the engine command-line arguments such as '--alt-preset standard'. I've attached a screen capture. Hope this helps.
-Zeke
WWFSMD?
#111110 - 16/08/2002 01:29 Re: High frequency cutoff in LAME with Audiograbber [Re: maczrool]
Mario
Loc: Ireland
Audiograbber?.....
I'll never understand why people, having the posibility to have the best windows ripper (EAC) for free use something substancially worst which is not free.
Would you buy a small car when someone offered you to get a Mercedes for free?...
.....just thinking.... :-)
Mario
Thanks / Gracias Mario The Spanish guy living in Ireland Homepage: www.livemyadventure.com
#111111 - 16/08/2002 05:25 Re: High frequency cutoff in LAME with Audiograbber [Re: Mario]
ah Mario,
That's a bit un-fair, AG is in no way substancially worse than EAC. But lets not talk religion as Ezekiel said.
maczrool, how are you having AG call LAME? internal or external, and with what settings?
#111112 - 16/08/2002 09:33 Re: High frequency cutoff in LAME with Audiograbber [Re: Phoenix42]
maczrool
Loc: Louisiana, USA
I was using the LAME DLL, which didn't have too many options. But, then I saw Ezekiel's post about the external LAME encoder and started playing with that last night. It is definitely better than the DLL, although I did have a little trouble getting the arguments to work at first. I believe I ended up using "%s %d -b 192 -s -F -q0 --lowpass 20" but I'm not sure right now, as I did it on another computer.
I think I tried EAC once and didn't like it. Audiograbber seemed to do what I wanted and I didn't have any problems with it so I spent the $15 or whatever it was. Thanks everyone.
Stu
#111113 - 16/08/2002 10:01 Re: High frequency cutoff in LAME with Audiograbber [Re: maczrool]
Ezekiel
Loc: NH USA
If you haven't tried EAC in a while you should give it another look. The interface was heavily redone and is much improved.
-Zeke
WWFSMD?
#111114 - 16/08/2002 10:43 Re: High frequency cutoff in LAME with Audiograbber [Re: maczrool]
SE_Sport_Driver
and check www.chrismyden.com/music/ for a cool setup guide.
#111115 - 16/08/2002 10:57 Re: High frequency cutoff in LAME with Audiograbber [Re: SE_Sport_Driver]
maczrool
Loc: Louisiana, USA
This thing needs it's own guide? I hate it already. The problem I had with EAC before and still have is that everything is so unintuitive to me.
Stu
#111116 - 16/08/2002 12:43 Re: High frequency cutoff in LAME with Audiograbber [Re: maczrool]
revlmwest
Loc: Hartsville, South Carolina for...
It also seems to have a lot of issues with xp.
Michael West
#111117 - 16/08/2002 12:58 Re: High frequency cutoff in LAME with Audiograbber [Re: revlmwest]
maczrool
Loc: Louisiana, USA
Yeah, I noticed its menus are a bit flickery on my XP professional system.
Stu
#111118 - 16/08/2002 14:23 Re: High frequency cutoff in LAME with Audiograbber [Re: maczrool]
SE_Sport_Driver
It is a bitch to set up, but that is why it is so powerful... you can configure the heck out of it. Once you do, all you have to do is his the "mp3" button each time you pop in a CD. That's pretty simple. I paid for AudioGrabber too and still use EAC.
EAC has no issues with WinXP or NT or 2000. All you have to do is install an ASPI driver.
#111119 - 16/08/2002 16:01 Re: High frequency cutoff in LAME with Audiograbber [Re: revlmwest]
Works fine for me on XP. What issues were you having?
