#112590 - 23/08/2002 07:02 2.0b13: Tuner search button bug is still alive
I just wanted to mention that the bug I originally found in 2.0b11, and posted here is still active in 2.0b13. Easy to reproduce, just press the "search" button in tuner mode twice. On my empeg, once I do this, visuals slow down and I can't play MP3's, among other quirky behavior.
Any notes on this bug in the internal bug database?
#112591 - 23/08/2002 09:30 Re: 2.0b13: Tuner search button bug is still alive [Re: tonyc]
It's still in the bug database as number 1817 and has not been touched yet.
#112592 - 23/08/2002 09:32 Re: 2.0b13: Tuner search button bug is still alive [Re: tfabris]
Okay, I've just given Santa's elves a nudge regarding this one.
#112593 - 23/08/2002 10:23 Re: 2.0b13: Tuner search button bug is still alive [Re: tfabris]
Hip-hip hooray!
#112594 - 23/08/2002 14:33 Re: 2.0b13: Tuner search button bug is still alive [Re: tonyc]
Hey, don't horray for me. All I did was nudge one of the elves. If they're busy making toys for all the other good boys and girls, it doesn't really make a difference, does it?
Besides, I may have nudged the wrong elf anyway. I'm told the tuner elf is on holiday.
#112595 - 23/08/2002 16:08 Re: 2.0b13: Tuner search button bug is still alive [Re: tfabris]
Yeah well a nudge is a nudge, I'll take what I can get. I know this isn't the biggest bug in the world but it gets me from time to time.
#112596 - 24/08/2002 08:19 Re: 2.0b13: Tuner search button bug is still alive [Re: tfabris]
Toby can probably fix it up, but he is indeed on holiday. He implemented correct RDS AF and TA support recently, which we can release when we iron out a few bugs.
#112597 - 24/08/2002 11:23 Re: 2.0b13: Tuner search button bug is still aliv [Re: tfabris]
Daria
Can you nudge someone about that "using the clock makes the player software crash"? I'm tired of my wife snagging me
#112598 - 24/08/2002 11:42 Re: 2.0b13: Tuner search button bug is still aliv [Re: Daria]
Is that confirmed to be a software bug?
#112599 - 24/08/2002 12:12 Re: 2.0b13: Tuner search button bug is still aliv [Re: tfabris]
Daria
Tell me how to confirm it. I have 2 units. Both exhibit the behavior. The player software resets but the player does not reboot, in both cases. This sort of limits what I can do.
#112600 - 25/08/2002 13:15 clock still killing player software [Re: Daria]
Daria
Since no one commented on what "confirmation" means, well, I can't very well do that. I did however have some fun with strace. Started the player and enabled "clock". This is with HiJack but I tried it last night with a stock 2.0b13 as well.
Anyhow, strace offers:
rt_sigprocmask(SIG_SETMASK, NULL, [RTMIN], 8) = 0
rt_sigsuspend([]player(142): memory violation at pc=0x0207b538, lr=0x02073a94 ()
pc : [<0207b538>] lr : [<02073a94>]
sp : bdfffc08 ip : bdfffc18 fp : bdfffc14
r10: 00000020 r9 : 00000000 r8 : 0214fdb0
r7 : 021b9aa8 r6 : 00000000 r5 : 02169108 r4 : bdfffc64
r3 : 021d10f8 r2 : 00000000 r1 : 021d0f48 r0 : bdfffc64
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0E5117D Table: C0E5117D DAC: 00000015
Function entered at [<0207b520>] from [<02073a94>]
Function entered at [<02073a48>] from [<0201a678>]
r4 = 02118BC4
Function entered at [<0201a1d8>] from [<02067804>]
r10 = 0214FC04 r9 = BDFFFD0C r8 = BDFFFD20 r7 = 0214FDB0
r6 = 02167BA4 r5 = 00000001 r4 = 02167B00
Function entered at [<02067774>] from [<020647c8>]
r7 = BDFFFD1C r6 = 0214FB28 r5 = 0214FDB0 r4 = 0214FB28
Function entered at [<0206476c>] from [<02064f50>]
r5 = 0214FC04 r4 = 0214FB28
Function entered at [<02064f24>] from [<0206526c>]
r4 = 00000000
Function entered at [<02065030>] from [<02064f88>]
r10 = 020AAF94 r9 = 0214FB28 r8 = 0000340E r7 = 00000080
r6 = 0000000E r5 = 0214FB28 r4 = BDFFFD64
Function entered at [<02064f78>] from [<020ab04c>]
Function entered at [<020aaf94>] from [<020b18b0>]
r5 = 0214FB40 r4 = BDFFFE40
Function entered at [<020b17e8>] from [<020e6c4c>]
r4 = 00000000
Function entered at [<020e53c0>] from [<020b162c>]
r8 = 021530D4 r7 = 021530C0 r6 = 020AAF94 r5 = 00000007
r4 = 00000000
Function entered at [<020b157c>] from [<020e6c4c>]
r5 = 00000000 r4 = 00000000
Function entered at [<021c9f14>] from [<00000003>]
<unfinished ...>
--- SIGSEGV (Segmentation fault) ---
+++ killed by SIGSEGV +++
#112601 - 25/08/2002 13:23 Re: 2.0b13: Tuner search button bug is still aliv [Re: Daria]
I'm sure you've said elsewhere, but refresh our memories. Exactly how do you reproduce this?
(Regardless, a segmentation fault is pretty damning.)
#112602 - 25/08/2002 13:32 Re: clock still killing player software [Re: Daria]
Daria
Actually I guess this is a good time to delve into kernel source and see if I can figure out what's going on.
#112603 - 25/08/2002 14:13 Re: clock still killing player software [Re: Daria]
Guessing, purely based on function pcs, it looks like it has absolutely nothing to do with the kernel. But I could be wrong.
#112604 - 25/08/2002 17:50 Re: 2.0b13: Tuner search button bug is still aliv [Re: wfaulk]
Daria
Use the "1" button on the remote to set the time field to "(clock)". Wait for the player software to die.
#112605 - 25/08/2002 17:52 Re: clock still killing player software [Re: wfaulk]
Daria
Well, I didn't think it had anything to do with the kernel, particularly, but i do want to figure out what was going on. If I can do something evil to work around the problem in the kernel, I'm not averse to that.
#112606 - 27/08/2002 03:14 Re: clock still killing player software [Re: Daria]
According to that backtrace it's falling over in std::string::terminate(). There's nothing you could do in the kernel to fix that. I'll look into it.
